1 - 15 of 15 Posts
Dear all
Does any one have some idea how many gallons or liters I have to fill in in the transmission fluid change? the last time I put 4 liters but since I don't have the manual, I'm not sure. can you help me please??, now my car has 46000 miles,
Thanks in advance
Daney
Transmission Fluid Change Info
Ya it's around 4 liters.. Just fill it till it pours out the fill plug.
You have the tool for the plugs right??
lumpylarry,
I'm facing the need to change transmission fluid in a Verona. You mentioned the fill plug and some special tools for the plug. Would you explain where the fill plug is, and what tool or tools do I need for the job?
Thanks, Ray
lumpylarry,
Thanks for the quick and detailed reply. Everyone should be as helpful a you are. This brings up some more questions. The car involved belongs to a friend and I can't get a quick look at it. The image seems to show a drain plug. I assume this plug is used to drain the fluid. But I think I remember seeing a pan like those found on most automatic transmissions. Does fluid change involve dropping the pan and opening what appears to be the drain plug?
Thanks again, Ray
lumpylarry,
Thanks for your help. The dealer wouldn't answer my questions on this subject. It is great to get the help you need when you need it.
Ray
1 - 15 of 15 Posts
