All the wires on the manual donor run into its ECM.
As far as I can tell, all that runs on the manual trans is the neutral safety (which would be in the ECM to and from the pedals, not the trans), reverse lights, and from the t-case the 4WD light.
I think all I need to do is wire up a switch to operate my reverse lights and it “should run.”
Well, all I’ve gathered from searching other old posts is that I won’t need to mess with the ECM (still not sure how to deal with reverse lights and 4WD light), but I’ll need two new driveshafts.
Was really hoping this wouldn’t cost me anything, but I didn’t realize the 4 speed was longer than the 3 speed and 5 speed manual.
Plus, this 4 door is mint. If I can’t make it look amazing inside and operate well I might just leave it an auto. There’s a few things I don’t like about an auto, but whatever.
The manual transmission should have a reverse light switch on it, and the transfer case should have a 4WD switch on it - it should be a relatively simple matter (compared to the rest of the swap) to locate the wires, if necessary, extend them, and connect them to the relevant switches.
Years....2 or 4 door...Engine type...Transmission...Axle ratio
89 2 1.3L carb. 5 speed man. 5.625
89-95 2 1.6L TBI 5 speed man. 5.125
89-95 2 1.6L TBI 3 speed auto 4.625
91 4 1.6L TBI 5 speed man. 5.375
91 4 1.6L TBI 3 speed auto 4.625
92-98 4 1.6L MPFI 5 speed man. 5.125
92-98 4 1.6L MPFI 4 speed auto 5.125
94-98 2 1.6L MPFI 5 speed man. 5.125
94-98 2 1.6L MPFI 3 speed auto 4.30
94-98 2 1.6L MPFI 4 speed auto 5.125
96-98 X90 1.6L MPFI auto or man. 4.625
96-98 4 door 1.8l 16V DOHC MPFI manual or auto 5.125
4.30 gears have a 10/43 tooth count
4.625 gears have an 8/37 tooth count
5.125 gears have an 8/41 tooth count
5.375 gears have an 8/43 tooth count
5.625 gears have an 8/45 tooth count
Related Threads
Suzuki Forums
604.8K posts
126.3K members
Since 2004
A forum community dedicated to Suzuki owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, reviews, maintenance, and more!
