Hi I have a 99 Jimny,
My in car heater only gives cold air even if I turn it to read and the fan only works on level 3 intensity. Any tips?
look under the bonnet near the battery for a cable that opens/closes a small push valve on a hose thats attacher to ur heater this could be the problem???
2 Problems...
Hi,
Your first problem of having no heat - have a look here:
Fixing car heaters
Your second, of having only 1 of 3 settings working will most likely be the switch worn, which will probably need replacing.
You could try to clean the contacts on the back though ;) .
Cheers,
Pommy.
