1997 Vitara JLX 4x4, 5 door, G16B 16V EFI,, 155,000 kms, on the "clock"
New here, been scouring the forums for answers myself. I have this dilemma myself, with my '97 Vitara JLX 4x4......My clutch started acting stoopid after it sat 2+ months during our rainy season. checked every aspect of the same issue having to start IN gear. 1st time this happened after it sat for 10 days, but soon as I got moving it freed up and worked fine, there after. Anyways, I just got a new Federal Mogul clutch cable to replace in my Vit....Have adjusted every which way possible, before the only clip holding the casing was on the driver fender/shock tower. I put in a bolt where the radiator clip was supposed to be, and zip tied it tight then 3 prong clip on the radiator don't do much good.
Anyways, the cables matched up exactly, when I put em side by side, after I got the old 1 out non-adjustable, rubber mounted style( wow 5 minutes work)
The weird part, was when I went to install the cable on the shift lever on the trans, it would NOT reach the bushing it goes thru !! Yet BOTH threaded cable ends are exactly the same length. Now after fully inspecting every part of the clutch system, in and under the car, I find nothing bent,or broken...I had to actually use piece of angle iron to push the lever forward, to get the threads into the bushing, and install the adjusting nut. Never seen such a thing in my life, exactly why I double checked both cables side by side for exact lengths.
So still with the .5-1.5 mm freeplay at trans, and 5mm pedal above brake pedal, with 1" free play and for extra I also finally checked the trans and diff fluid levels FULL.....Pulling what hair I can, out SMH lol .....NOTE the car/tranny drove and shifted prefectly great before it sat 2+ months, what am I missing? I'm a lot smarter than what I'm working on, just don't have my massive 40 year tool "collection" here with me in Asia ughhhh
Forgot to ask, where is the VIN plate on these dang units? Not sure if its import from Japan or what all I find is on firewall saying is G16B, 16 v., SE 416, white. The paperwork I have don't even show a VIN like US cars lol
