The 100 amp fuse is bolted in and yes it may affect the charging, Test the circuit before replacing, it would require a dead short to blow it..
How does it come out of the socketThe 100 amp fuse is bolted in and yes it may affect the charging, Test the circuit before replacing, it would require a dead short to blow it..
Did you miss this ?The 100 amp fuse is bolted in.
HEAR ! HEAR !.I've seen discussions on this forum run for literally months over simple wiring issues that I could have resolved in an hour or two had I been hands on.
I tested it at the battery, and it reads 12.06v on/off revd up or idlingIs the alternator actually bad? Have you tested it at its output terminal? The big stud one? What voltage is there ign off? What voltage engine at about 2500 rpm? If you gave 13.5 or better at the terminal, then the alternator isn't your issue.
Test it at the alternator output stud, as I requested to prove alternator is actually faulty or not. Once you prove that then you know whether its a wiring or fuse issue, or a dead alternatorI tested it at the battery, and it reads 12.06v on/off revd up or idling
I shorted across the fuse and the ohm meter started reading 14.6 so the alternator is good now just need to replace the fuseTest it at the alternator output stud, as I requested to prove alternator is actually faulty or not. Once you prove that then you know whether its a wiring or fuse issue, or a dead alternator
Can you post a photo of it pleaseYou keep saying it is bolted in, my is attached to the positive cable on the battery
