Having electrical problems with my 1.5 sport m15a engine and need to remove the alternator. I have disconnected it I cannot remove it from inside the engine compartment without removing something it seems but haven't a clue what the best/easiest thing is, any help would be great. Thanks
It's normal to have to remove something else - don't be scared.
These cars are assembled with robots. Alternator is attached to the engine, then engine is fitted to subframe, then subframe is lifted up into engine bay.
On my 1.5 Allgrip I removed all the mounting bolts (accessible from within the wheelarch) and then hung it on a piece of wire through one of the mounting lugs as I carefully pushed one of the brake pipes into the ABS unit to one side to lift it out. I think I also removed the air cleaner to aid access.
