You have a serpentine belt, this is secured/tightened via a spring loaded idler pulley, use a 1/2" ratchet to release pressure and slip the belt off a pulley... Install in reverse order..
Umm - not on the H27a V6 - there's no spring loaded tensioner there, you have to loosen the alternator and swing it on the pivot.
All of the info needed is sourced from the top FAQ thread. ;)
As tough as they are to turn, most folks end up in deep doo doo with a rounded off or broken bolt. I'd suggest just muscling that alt in and back out with a pry bar on that pivot bolt, and leave it alone otherwise. ;)
It IS a pivot point, verses an the adjustment / belt tension securing fastener, of significant torque holding need.
Ref:
