1 - 13 of 13 Posts
All The Basic Info People Ask About When They First Get On Here
TO START I am making this thread because I wanted something that people could turn to when they first get on here and need to know some info fast and make it easy to find, I am not saying that i am an expert so if anything on here that i have said is wrong feel free to correct me.
The Forenza and the Reno are the same chassis, suspension and power train. The only real difference is the body and the interior. There are European and Canadian, Korean Models that are the same but named different.
Chasis models
Forenza/ reno: base, convenience, and popular (not available on Reno)
The differences are just the option that come with the car. They all have the same D-Tec 4 cylinder engine. There are only 2 different transmission either automatic or manual, I do not know the model numbers.
RIMS and TIRES:
The lug pattern is 4X114.3mm offset is 40
The stock size rims are 15", they are wrapped in 195/55/R15
If you have the stock tire pressure monitoring system (TPMS) the sensors are built into the valve stems like all GMs
After market Rim sizes are found in this link, there is also a link in there to calculate tire size,
http://www.suzuki-forums.com/suspension-brakes-wheels-tires/18696-need-tire-wheel-advice.html
LOWERING SPRINGS:
There are very limited options for our vehicles you have APEX springs and use stock struts or go all out and get variant coilovers
COLD AIR INTAKES
BMS CAI REVIEWS
http://www.suzuki-forums.com/forenza-reno-performance/27372-cold-air-intake.html
RANDOM CAI
http://www.suzuki-forums.com/forenza-reno-performance/25306-cheap-cai.html
SPARK PLUGS:
The Spark Plugs NGK-BKR6EK, BOSH-FLR8LDCU there are others but these are the 2 closest to stock (im sure the stock one is a bosh)
How to change them http://www.suzuki-forums.com/forenza-reno-performance/26554-how-change-spark-plugs.html
How to change the SHIFT KNOB: http://www.suzuki-forums.com/interiors-exteriors/22963-shifter-knob-removel.html
SO these are just a few things that I have come up with by doing basic searches. If you have something else that you want to add Go right ahead, please add a linkback to the thread you found the info on, thankyou.
If you are interested in purchasing anything for our cars KinkyLlama has a lot of parts up for sale most of the time.
Pyaaw, I read message. I recently got 2004 Forenza with 2.0 engine. I need to know
what aitifreeze to use. It has 30,000 miles and requires a complete aitifreeze change.
The antifreeze in it now is between orange & yellow color.
Thank you very much James L.
James L, As long as it is DEX-COOL approved coolant you are fine.
Modifications for the car to date
Suspension:
BMS Sway bars (Kinky motorsports, boshart motorsports)
KW Varient 1 coilovers (Kinky motorsports, boshart motorsports)
KW Varient 3 coilovers (Kinky motorsports, boshart motorsports)
Kinky Lower control arm brace (Kinky motorsports)
Intrax Lowering springs
Apex Lowering springs
Engine:
Light weight UD pulley (Kinky motorsports)
BMS cold air intake (Kinky motorsports, boshart motorsports)
Kinky 4-2-1 header (Kinky motorsports)
Magnacore spark plug wires (8mm) (Ebay)
First cat delete pipe (Kinky motorsports or member Syth)
Kinky Mid pipe (Kinky motorsports)
Brakes:
Wilwood Big Brake kit (kinky motorsports)
Stock size slotted/drilled rotors (Ebay)
Green stuff brake pads (Ebay)
Exterior:
Forenza/Optra Lip kit (Kinky motorsports)
Reno/optra 5 Lip kit (Kinky motorsports)
This is all i can think of right now. These parts are designed for the car and are relatively easy to get. Anything beyond these parts,your gonna need to ask and search around. Hope this helps alot of new members
Hi, Great info,Maybe you could help. I have a 2004 XL& 4wd just put new tires on. Replaced the orig Bridgestome with KUMO sloris. The orig tire pressure placard states 26 front and 36 back. Biggest range I have ever seen. I want to just go with 32 all around for even wear. any Ideas?
Richard
The big difference in the tire pressure is probably due to it been a 4WD. In most cases you'd keep them at the same pressure so that you can get good gas milage on the road (highway and city driving). Im assuming the 26 is for when your going offroading as a lower tire pressure will help grip on offroad surfaces
Discussion Starter #10
Richard
Like phatslaya said, it is most likely for offroading. are the replacement tires the same exact size as the old stock ones?
And 32 sounds fine, basically as long as you are below the maximum rated tire psi for the tire manufacturer (thats cold psi) you are ok. Just keep an eye on your tire wear. because zuki may have the fronts lower psi to keep the front suspension in alignment. not that 1/8 of height will do much in the short run, but over time it may.
what psi did you have in your old ones?
Discussion Starter #11 (Edited)
ADDING TO THE FIRST LIST:
Shift knobs: our cars have the lift reverse style shift knob for the manual transmission.
follow the link here, go to the fourth(4th) post and there is an explanation and 2 pictures showing the difference between the two styles.
SHIFT KNOB REMOVAL PROCEDURE: follow the link to the diagram
The Idle Learn Procedure (thanks to zstalker)
It is a good selection so far, but many other good analysis are still missing. I will add some of them soon. Keep up the good work. ;)
jeux de machine a sous
gratuit meilleur casino en ligne
Jeux de
casino en ligne Plus de 140 Jeux de casino en ligne. Gagnez des
jackpots enormes.
jeux
de machine a sous gratuit meilleur casino en ligne
1 - 13 of 13 Posts
