What things have gone wrong with my XL-7? There are air leaks through the vents. How to get rid of this? People are you also facing same problem or it is with my car only?
Hi demontay ! Why don’t you go to the service center, might be they can find out the problem and may be the dealer will help as its in the warranty period.
That may not be all that abnormal. I've had several cars that even with it set to recirculation some outside air is forced in while driving. But still, take it to the dealership and see if they can check the seals in the ventilation system.
Air leaks? Its called ventilation, its your fresh air setting, even in the off possition it will bring fresh air in...as a smoker, Id turn my vent off...but if your a non smoker and this just annoys you, turn the setting to recycle, that should stop it...but really its quite normal.
BTW if you smoke I wouldnt suggest using the recycle feature, it will make your A/C smell like crap! Atleast while your smoking, I wouldnt use it.
