1 - 8 of 8 Posts
Hello guys.
Seem to have a big problem obtaining an air cleaner element here in panabo. Can anyone recommend an alternative element that will fit?
I have a 1992 Every 660cc 12valve. not sure of the engine type.
Be greatful for any advice on this one.
Also slight problem on starting lately. gives the impression the battery is too weak although the battery is good. Could this indicate the starter motor needs replacing. sometimes it starts just fine. :rolleyes:
Hi there1
Where is panabo?
I assume the location of your van's engine is at the rear and I 'm not sure if any aftermarket filter will fit in it but I guess you could try.
My van's engine is located in front and i just put any aftermarket airfilter and just fabricate the pipe. It is similar to the link below.
About your starter, you can try adding relay to it. That's what i did and it never had any problem on the starter. I just change ignition coil as my stock coil has broken.
Hope this helps.
�V‹KŠiƒGƒuƒŠ�[�iDA52�A62W�j ƒ`ƒ…�[ƒjƒ“ƒOƒ�ƒjƒ…�[
ƒGƒuƒŠ�[�iDE51V�j ƒ`ƒ…�[ƒjƒ“ƒOƒ�ƒjƒ…�[
Hello Yellowturtle.
Panabo is in Davao del Norte. mindanao.
My van is rear engined.
Will try adding a relay next week to the starter.
Will also experiment with fitting a different filter.
ant thanks for your comments Yellowturtle. Much appreciated.
Not yet, I am waiting till I can get into Davao city to obtain one. (think I will get several as they are hard to find here at the moment)
Thank you
1 - 8 of 8 Posts
