1 - 14 of 14 Posts
Hello
I want to install Ac on my GV from 2003. I bought one AC unit from a 1.6 2001 GV and i didn`t find in the electrical wiring the ac relay. Can you please help me with the AC wiring diagram for GV 99-5?
Regards
Well maybe not
Where are you located? 1.6L GV's are not the norm for 2001 (here) thus the probable disparity in schematics / manual info. :(
Discussion Starter · #6 ·
That PDF should support. :huh:
I'll dig deeper in the morning.
Thanks alot. I am from Germany.
In the AC electrical installation provided by the seller i can`t find B04 relay (compressor relay) and evaporator temperature sensor if the diagram provided by you if for the 99-05 GV. I didn`t understand why he sent me the main fuse case with all the fuse in it. Is there any chance to be there the ac relay compressor?
That era (North American provided at least) SQ series Vitara utilizes a compressor relay as depicted in the diagram above, if that is what you are asking.
The evap temp sensor SHOULD be configured on the evap housing proper.
Where was your vehicle made? UK, Spain or?
Ok, but I don't see your point other than your individual components are just in different locations I suppose. :huh:
1 - 14 of 14 Posts
