1 - 8 of 8 Posts
1999 grand vitara 6 cyl. I have tried two different hoses from recharge kits both wont attach all the way? Is there a special fitting i need?
Your A/C lines should have connections that look like the R-134's shown here...
And the charge hose end with a quick disconnect where you pull back the outer (silver, spring-loaded) ring, attach / push on to the service connection and release the ring.
Yes max I am very familiar with ac recharging. I was wondering if anyone has had trouble using the standard connectors. On two different occasions I have tried to connect two different hoses from two different manufacturers and I pull and push and shove and all I have done is lost some of my existing freon. I really dont want to pay a shop to do what I can do.
If you have the R134A fittings, the O rings in the gauge set may be dry, lube them with some silicon spray, retry...
Mine need to be wiggled slightly to insert....
..... Philip
Discussion Starter · #6 ·
Sorry max that wasnt supposed to read as sarcasm. I truly appreciate your quick response.
Discussion Starter · #7 ·
Ok aqua I will try more i just didnt want to vent all my freon out. But I guess my options are limited.
It's all good. ;)
If you don't have the silicon spray, try just a smidgen of Vaseline or "O" ring lube. Reefer oil would be ideal if you have that too. It takes a bit of force to get them on. Check for any burrs on the fitting, that can hang you up.
1 - 8 of 8 Posts
