My Son has purchased a Vitara for off road use.It requires some work to make it fit for even off road use! The registration plate is for 1996, it seems to have a 1.6 engine, 2 doors, a tonneau cover on the roof and 4 wheel drive. Not exactly sure what it is, which is not helping the search for parts. Is it a mk1, 3 door, open? I know nothing about these cars and wondered if this forum could help.
When we collected the car we pushed it out to have a look, before starting it and driving it a few meters. When it arrived home it was difficult to push, even with it in neutral, brakes binding perhaps, resulted in towing up the drive? First job was to fix front offside caliper. With that wheel in the air and no caliper I tried to rotate the wheel. I was surprised to see that as I did this it was trying to move the nearside wheel which is on the ground. As the car is in neutral I was expecting it to turn the pinion wheel on the front differential instead. Is this correct or is there some issue with the differential?
