Hi all,
I have an '07 Reno that I recently have been able to figure out has a bad valve and leaks any new coolant I put into it. So, I went and got a kit with the tool and four new Schrader valves to remove the broken one and insert a new one. However, the tool does not work, it doesn't get a bite on the valve (it does work on the tire valves, though).
Has anyone experienced the same problem? Is this valve different than a Schrader valve and I must do something else? It's getting into the 80-degree range here in New York now and will go crazy if I can't get this fixed soon.
All suggestions are appreciated! Thanks!
It sounds like the Schrader is booger'd up. :(
If the leak isn't huge, you should be able to cap it with a quality cap that has a seal within it.
It would be an inexpensive attempt at least.
This style cap...
Is it on the low pressure (cold) side? That would be a plus. ;)
Apart from the normal valve tools, needle nosed pliers usually works - although it can be kind of hard on the pliers (they are not designed to apply a twisting force and can end up with the nose twisted).
