1 - 1 of 1 Posts
Hi everyone
I have a '93 1.6L 8V manual trans 2 door Tracker
I bought it with a trashed dashboard and a stolen stereo.
I rewired the A/C myself:
From the ignition key, a wire powers the dashboard A/C switch which goes to an additional relay that powers the pressure switch, then the compressor and the front fan.
I then added a wire from the dashboard A/C switch to the VSV as increase revs while the A/C is on (I still have to properly test and rewire the A/C amplifier circuit board).
However the A/C doesn't seem to cool much despite:
Having removed the compressor, checked for leaks, added the proper oil amount to the compressor
Tried an R12 replacement
Tried an R134+additive (helps a little bit, but not much)
Checked the pressures (and they're fine)
Vacuum evacuated the lines
Properly cleaned the dryer with solvent (I couldn't find a new, identical replacement dryer here)
I tried another compressor
But, even at high engine speeds the A/C doesn't cool much in warm weather.
Any ideas?
1 - 1 of 1 Posts
