I would like to add coolant to the AC on my 2004 Forenza. Where is the compressor and input located?
Thanks.
hi gts welcome to the forum! before you go an add coolant, do you know if the coolant is low? too much pressure is bad for the system. is there a leak somewhere? is the system working properly? the best thing to do is to have the system checked by a pro before you go messing around with it. if there is a problem with it you could end up making it worse. any other questions just ask
