1 - 9 of 9 Posts
Hi guys . I just replaced couple weeks ago new A/C assembly clutch . when i got it i checked and its exactly same as old one , but its anyway has some rattling or rustling sound during spinning , its definetly again A/C clutch but its new ... why whats the problem ? of course it doesnt has so strong sound as old one but still has some small. its suzuki grand vitara 2006 .2.0 engine
Have you diagnosed the refrigerant and compressor side? You may be attempting to spin the pulley / clutch assembly against excessive head pressure or internal mechanical binding.
does the sound occur only with the compressor engaged? if its there with the A/C off, check the pulley bearing as wear in that can allow for excessive movement of the pulley resulting in the clutch rattling.
Discussion Starter · #4 ·
I replaced new Clutch pulley . but its again has rattling sound :( what it can be ? sounds like stone to stone .
Is it definitely coming from the a/c compressor! And I ask again, is it doing it with a/c on or off? If its a clutch clearance issue then it can be noisy with air-conditioning off and quiet with ac on
And I ask again...
Discussion Starter · #8 ·
it has rattling sound even A/C is off or ON on dashboard. anyway dose. but clutch engaging automaticly somehow and more loud sound has that moment.
No, HIGH refrigerant pressure (over charge?) or internal compressor damage / noise.
You need to acquire the services of a local hands-on A/C Tech to evaluate the system. This long distance troubleshooting isn't getting it if you haven't the tools and talent to support our suggestive efforts. Sorry. :(
We also have a language misinterpretation that clouds the statements as well.
Reactions: foxyice
1 - 9 of 9 Posts
