1 - 13 of 13 Posts
At idle I'm getting grey smoke out of tail pipe. What would cause this?
Sent from my moto z4 using Tapatalk
Some type of oil... time to investigate
pcv valve is always a good place to start
Replaced it less than 6000 miles ago
Just because you replaced it doesn't mean it's not faulty, clogged or stuck. Or has the incorrect spring tension. Is the pipe oily between the valve and Manifold? If you remove the pipe and plug it to prevent vacuum leak, does the smoke stop?
Have not tried that. Will though and report back. Thanks.
Did you use the correct PCV valve? Many PCV valves appear outwardly identical, but they are not interchangeable.
I would also suggest wet & dry compression tests.
Discussion Starter #9
Tried the pcv valve delete. Still getting the smoke.
Step two has already been suggested - wet & dry compression tests ...
Discussion Starter #12
Now can someone tell me the psi range I should be in please for test
Grab the SQ series Service Manuals from the FAQ thread for the specs. Then with a fully charged battery, open throttle, all plugs removed and preferably a warm engine...crank away.
You can Google the procedure for video details if needed. Or if conducting a leak-down test instead the details surrounding the procedure.
1 - 13 of 13 Posts
