'98 Tracker Remove Alternator
586 Views 2 Replies 2 Participants Last post by  mkuchar67
Hello! I removed the 3 bolts and the plug/screw. The alternator moves back and forth but I can't pull it off bottom mount area. How do I remove it? And is it removed towards the top or underneath? Thanks!
Motor vehicle Automotive tire Light Rim Bumper
Automotive tire Motor vehicle Automotive lighting Automotive exterior Gas
See less See more
2
if you took the 3 M8 bolts out, it should come off....
try using a tire lever (but no brute force!) between the alternator body and the bottom bracket (see bottom picture) to leverage it out. some WD40 could help too.
Reactions: 1
I got it! I just need to tap a screw driver on each side until it came off. Then remove a mounting bracket above it to pull it out.
Reactions: 1
