ok, so after a night key off, the battery dropped to 2.66V, completely drained...
I charged it for some hours and vol came back to +12.50 volts...
I made a drain amp test and the result is dhown on the pic 1.90amp !! that explain the drainage.
So what I did is removing the black wire the goes into the 80amp fuse, this wire goes to the alternator.
Then I did another test and the amp drainage drop to .01 !! I reconnect the wire on the fuse and amp drain pop up to +1.90amp....
So the problem is alternator direction, probably a diode... I'll replace the alternator...
I'll still go ahead and track wires from the ignition switch.... I'll come back to say where those are heading....
photo below shows where I disconnected the alternator wire in the fuse box....
