1 - 10 of 10 Posts
· Registered
Hi all, I know that the relay is located under the dash, but am unable to exactly pinpoint and remove it, also, does anyone have a part # . I keep hitting a dead end. Any help would be greatly appreciated.
Thanks.
· Registered
Which relay? As far as I know the baleno only has fog light relays, headlights do not have any relays.
What's your actual problem / symptoms?
· Registered
HI, thanks for getting back to me, my wiring diagram shows one, under the dash, with power window, airbag relay etc, I can physically see them but impossible to remove. The headlights will not turn off, even if you turn off ignition and remove key. Front only.
· Registered
Ok, that's a new one on me, never seen one wired like that
· Registered
Discussion Starter · #6 ·
After a lot of headbanging I have found the OEM part No. Which is 3886060G20. Just got to work out how to remove it and source a replacement, they are like hen's teeth! I will update if I get anywhere.
· Registered
Reactions: Zammo 77
· Registered
Discussion Starter · #8 ·
· Registered
They are a "standard" automotive relay on a lot of vehicles
· Registered
Discussion Starter · #10 ·
The relay came today, it was a total b%&£*%d to gain access to the junction box where it is located, but I have now changed it and the problem is now resolved, very happy. If anyone need more details of the the procedure then please feel free to ask.
1 - 10 of 10 Posts
