Hi guys I have a 96 tracker and the darn rear axle shaft won't come out....I have taken off the brake drum/pads and all...and have taken off the 4 bolts holding it in...now I got it to slide about a 1/4 inch and it's stuck...is there something I'm missing?
Are you using an axle (sliding hammer) puller? :huh:
Like...
A free Auto Parts Store loaner tool. ;)
[I think you're doing everything right. The FSM recommends using a slide hammer if the axle doesn't come out easily.]
Here's a crude method, take a length of chain, big enough that the studs can go through the end link ,put a nut on and give 'er a snap.
Thanks guys
I ended up having to put it back together...it's totally seized in there...it still rolls so I guess I'm just gonna have to turn the radio up louder for now....I broke a slide hammer, and splintered a 2x4 to pieces beating on it...I'm tired and my back hurts so I slapped it back together...if the bearing totally goes maybe it will snap it loose...then all I gotta do is replace the axle...dunno what else to do at this point I need the car for transportation...but thanks for all your suggestions I really appreciate them :)
