Hello, I have a 95 Tracker 1.6 16V motor out of my tracker cleaning up some leaky gaskets and such. I'm trying to cheat a little and do the valve seal replacement without removing head or lifter arm shaft. I bought the Lisle 36200 tool for removing the keepers/springs and was successful on the first exhaust valve. The second exhaust valve is so close to the head casting that the tool won't work. Does anyone know of a tool better suited for this job? And yes, cam is out of the way. I think it will work if someone makes a smaller version of the Lisle tool. The magnets in the tool are great for recovering the valve keepers! Thanks in advance for any advice.
for the cost of a head gasket, pull the head, check it over, give the valves a lap and do the seals. you slip and drop a valve down the bore and you're going to have to take it off anyway.
You may be interested in doing this backyard style. This guy has some great ‘old school’ tricks. This one may help you:
https://youtu.be/bohwemehdIk
