horn works with the engine off, most of the time when engine is running in park but once you are in drive and driving works 10% of the time. Any suggestions
You have a bad ground somewhere... First check the ground straps on the steering column..
.... Philip
The switch gets its ground on the steering column. The horn relay, mounted to the ECU, gets its ground in the engine compartment just by the windshield wiper reservoir
