1995 sidekick 16v motor, I did the harness.. everything works. except im getting cel 41 and the injectors wont fire @ the dizzy I have 12v on the blue and ground on the black and the white goes straight to the ecu... anyone have any ideas??? Thanks in advance...
check engine code 41 means the ecm is not see a 12v signal on neg side of coil when ignighter is open. first check is to disconnect ecm , turn key on and check for 12v at connecter side terminal A8.
let know what you find and we can go on to the next checks.
squid
Thanks... got it handled lastnight it was A8 the harness that I got off the kick did not have the noise reduction filter I got one @ Petroworks today.. Its running fine now.. Thanks for the info.... By the way has anyone successfully chipped or reflashed these ecus yet??
