My sons Tracker had been running fine when one of the springs broke inside the clutch. We pulled the engine, replaced the clutch and pressure plate, put the engine back in and it wouldn't crank or start. I figured I missed installing or broke a wire. I have searched all the forums, chased down all the fuses, relays, wires etc. that I could and am stymied. I printed out all kinds of wiring diagrams but couldn't find a starting circuit diagram. It still won't crank with the key, but I can jumper the solenoid and it spins it over like crazy. Everything including power to the coil, pump, injectors etc work fine. But still no crank with key and no spark. It appears to have no power on the red and black wire to the clutch neutral switch which it should, but I can't seem to trace where that red and black wire goes. If anyone knows where it goes, or has a wiring diagram for the starter circuit I'd sure appreciate a link or your suggestions.
Thanks,
Smiley
Thanks,
Smiley
