just got a 94 kick with 1.6 16v with engine issues.
has problems with emissions CO & HC are way above allowable limit.
hesitates off the line (auto tranny)
going 100kms (cruise control) rpms go up & down 3000 - 3200 rpms
anyone out have any ideas or suggestions
Most likely getting the TCC to lock and doing a full tuneup with new plugs, wires distributor components, and timing with a light will fix many of your issues.
As this car is new to you, I would start by doing a compression test to check the timing of the engine, and post your results. You should be getting about 190psi on a warm engine with a fully charged battery. Do the test with all plugs out, and the gas pedal floored when you are cranking. It is easy enough to do on your car - just pull the F1 fuse to stop spark and fuel.
Also advise if your check engine light is on with the key on, and off once the car starts. If you plan on keeping the car, and don't have one, I would spring for a scanner so that you will be able to communicate with the ECU.
