Selling a '94 Geo Tracker; off-road modified, but still street-worthy. It has been out off-roading an works well. Would be a great launch point for someone who wants a neat little trail runner or would like to get heavy into modifying a unique wheeler.
Details:
-1.4L
-130XXX miles (not sure of the exact number)
-Manual transmission
-Manual windows
-Convertible top
Below are modifications made:
-Solid axle swap (D35 rear and D30 front from a Jeep Cherokee XJ) w/ 4.10 gear ratio
-4-link suspension rear and 3 link suspension w/Panhard front
----All links are 1-3/4"x.25" DOM tubing----
----All rod ends are 3/4 Heim Joint Chromoly Bung Weld----
-Coil suspension (front and rear coil springs from 2-dr Jeep Wrangler JK)
-Shocks (two sets: one from 4-dr Wrangler Sport and other from 4-dr Rubicon)
-Tires: 30x9.5x15 General Grabber AT2 mounted on 15x7 Cragar Black Steelies
----4 mounted and one matching spare----
Other updates:
-Aussie Locker in the rear axle
-All links and axles have been painted with Por-15
-Has been set up to install a CB
----Wired to run both radio and CB off CB antenna----
----CB and radio will need to be mounted in console----
-4 point roll cage
----Rear kicker legs are not currently mounted to body
-Interior has been Rhino-Lined
-New steering wheel
-New battery
-All fluids maintained and changed at end of fall
-Bikini top
-Grenade shift handle available
-Rear bench seat has been removed
-I have a 5000 lb winch that will be included
-I have the start of a front and rear bumper that can be included
Email ([email protected]), call or text (612-298-0687). $2500 obo - I can provide more pictures if needed. Located in Maple Plaine, MN.
offroad, off, road, jeep, suzuki, sidekick, samurai
Discussion Starter #2
Realized I said 1.4L, it is a 1.6L. It is also slightly under 118000 miles
Located in Maple Plain, MN - I am now selling the car for $2000 and $2500 gets everything listed.
Selling everything for $200. Feel free to , reply, direct message me or reach me on my phone (612) 298-0687
Also, this does have two of the slip yoke eliminators. The slip yoke eliminators have not been bolted firmly to the transfer case output shaft, but if you do so you can update to a splined CV shaft for even better offroading strength.
I have two of the slip yoke eliminators from Low Range Offroad and I believe two of the tracker/suzuki/toyota conversion flanges...
