So I bought my first carry the other day and know very little about them. My 4wd doesn’t work. The lever functions and engages the shaft however the diff and axle lock buttons don’t light up or seem to do anything. One wheel spins in low traction situations no matter what I try. What should I check?
The actuators on the axles are vacuum operated. I believe you can actually see them move it you are under it when the engine is running and the switches are turned on and off. I'm confused by your statement that one wheel spins in low traction mode though. Is this one of the front wheels or rear wheels. If a rear wheel spins that would indeed mean that the rear diff is no locking. If a front wheel spins but the other is pulling, this would be normal, as the front axle lock engages the front axles, but is not a differential lock.
