Headed home Driving on freeway after a 5 hour trip. Suddenly the sidekick looses acceleration and stepping on gas does nothing. Had to pull over. Seems like a fuel issue or transmission issue? Any ideas?
Thank you and I’m trying the best I can. I understand that explanation without being onsite is challenging for me and you as the recipient. Loosing acceleration on the freeway, pulling over and vehicle stopping completely and then unsuccessfully trying to restart are all related. As of now the vehicle will not start, but does crank making the rrr-rrr-rrr sound.So now we're getting a different picture - it apparently isn't starting - big difference from the initial post.
By the way - you're going to have to get some details correct - when you turn the key to the start position, and then engine goes rrr-rrr-rrr - that is the sound of the starter cranking the engine or turning it over, if you get a click and no rrr-rrr-rrr, or maybe no sound at all when you turn the key, that would be not cranking or turning over.
We're not there to see/hear/experience what is happening, you have to tell us, and if you're having trouble explaining it, then the feedback you get will be misleading.
The odometer is 5 digits. When I bought the vehicle from the grandson of the original owner he assured me that it had not rolled over since 185000 would be more plausible. So…who knows??And one more question. Since it's a '92, does your odometer have 5 or 6 digits? If 5, and it shows 85,000, it might be 185,000 instead. But if you have 6 digits, it's only had <3,000 miles per year -- about eight miles per day!!! If it has 5 digits, it's time for pressure check of the cylinders.
This one takes us to the flip side of the forum assistance conundrum - how can you tell whether the person guiding you knows what they are talking about?How do I check pressure of the cylinders?
It’s a 16 valveStep one should be to identify what we're working with - a 92 Sidekick - is it an 8v engine or a 16v engine - 16 valve engines say so on the timing cover.
Step two would be the basic tests - an engine needs three things to run, air, fuel, fire - what are you missing? The easiest to check are fuel & fire - remove a spark plug, hold it against the cylinder head and have someone else crank the engine, are you getting a spark? If there's no spark, you're going to focus on the ignition system - connect the spark plug to the coil and repeat the test.
If there is a spark, refit the spark plug and spray starting fluid into the intake whilst cranking the engine - does it fire up & run on the starting fluid? If it does, then you're not getting fuel and you know where to focus.
No spark that I can see.If there's no spark, you're going to focus on the ignition system - connect the spark plug to the coil and repeat the test.
You say you have "normal dash lights" when trying to crank - do you have charge, oil pressure & check engine lights when you turn the key to on? If you do, pop the distributor cap off and see if the rotor turns when you crank the engine.Does this look right for testing? In cranking with this setup, no spark.
replaced rotor and cap. Rotor turns when cranking the engine. Still does not start.You say you have "normal dash lights" when trying to crank - do you have charge, oil pressure & check engine lights when you turn the key to on? If you do, pop the distributor cap off and see if the rotor turns when you crank the engine.
What we're doing here is checking to see if the cam belt broke - primarily because it failed suddenly - there are other possible causes for no spark, but lets get that one out of the way.
