Hey whats up. I have a 1992 Suzuki Samurai. This is kind of a weird question, but im away from my car (actually a state away) and going to order a new drive shaft. I was wondering if someone could give me the dimensions of the joint flange on the rear differential. Like the LxW and also the bolt hole dimensions. Please help, and Thank you very much!
The Sammy only had two different flange bolt patterns. Your 92 uses the larger bolt pattern. Here is an piece from an old article about driveshafts I did a few years ago...
The large flange pattern measures 2 5/16" from bolt center to bolt center. Its larger nuts and bolts can be removed with a pair of 14mm wrenches.
Sammy Driveshaft rebuild
