i been having this problem for a bout 3 years the Fuel Injector on my 8v engine has been not working then when you clean it it will work agen dose that mean that its bad or woth
Dirty fuel my friend, check the filter and fuel tank...
.... Philip
And definitely the fuel tank. Have you ever dropped the tank and checked the condition inside? The screens on the injectors are quite small - any tiny particle of rust can clog them up - if your fuel tank is rusting inside, this can cause this ongoing problem. The fact that cleaning the injector screens helps your problem for a while would seem to indicate that the particles coming from the tank may be small enough to pass through the fuel filter
