Hey there everyone, happy to be part of the tracker family. Just picked up a '90 with 199k mi (mostly towed behind an rv) and already enjoying having a manual again.
'90 Tracker, 8V, 1.6L, 5 sp, 4wd, 2dr soft top
So I have need of a little assistance in fixing a high (2k-2.5k) cold idle that also surges. When first started it has a surge of about 500rpm and once warm it's sitting at 1500 with about a 1-200rpm surge.
I've found a couple older threads here with details on checking several items, but unfortunately the pictures are no longer populating so I can't see what's being pointed out. Based on descriptions I'm pretty sure I've found a couple items but wanted to make sure.
www.suzuki-forums.com
I have decent heat but the gauge doesn't come up much above cold (assuming the sensor is worn, will ohm it out when I'm home.) Also need to replace the blower motor, but that's relatively straight forward.
There's also an odd whirring/gear sound coming from (seemingly) the rt front tire whenever I'm coasting above 20mph with the clutch in or for that brief moment between letting off the gas and the vehicle being slowed by the engine. Which, if I put it in neutral and lightly push the shifter toward any gear (with clutch in of course) the sound slightly dies down... Maybe a clutch issue?
Lastly, I doubt the ecu has been touched so I'm going to get new caps on the way for that (still haven't searched for the thread with that info yet.)
Thanks everyone!
geo tracker high idle after warm
Hey all, First off im a new member and new tracker owner. I love this little truck and have some major plans for this ride. First off, the truck cranks and warms up fine. Once it is up to running temps the idle starts to creep up. All the way to 3k at times. Any ideas on this? Vaccum...
1990 Geo Tracker lurching at all RPM's
First of all, I will describe the issues. To start it, it takes two attempts before it will run, and then it will not stay running unless I blip the throttle every couple seconds, and this will not go away until it's warm, which my voltmeter temperature sensor says is 160 F on the radiator...
Thanks everyone!
