1 - 1 of 1 Posts
Hi Guys!
I'm in Canada and I have recently imported a 1990 and 1991 Suzuki Carry from Japan.. I am having a small problem with the 1990 one which I thought maybe you knowledeable people might have come across..
It has the F6A 660cc engine (fuel injected). For some reason, it will idle fine for about 5 minutes but then after about 5 minutes of idling it will turn off.. And when restarted it will turn off again unless you give it gas.. In other words, it doesn't want to idle unless you give it some gas..
I'm not sure, but is there an idle bypass valve in these trucks that lets air go through during idle? (ie. when the gas pedal is not pressed)
Any info would be appreciated! thanks!
1 - 1 of 1 Posts
