Hello Everyone, I have a 90 samurai that had a noisy transfercase in 4wd. I'm building this samurai and decided to rebuild it with a 6.5 transfercase gear kit. (i will try and giva all details so you know whats been going on) first the shifter sheet was gone- just small pieces and mush so i cleaned it out. I took out all bolts etc needed to take it apart in cluding speed gear (metal ball) and the detent bolt/spring and ball. my problem started when i started pulling the main case halfsapart when the shift yoke fork stopped half way out and wouldnt come out the case. I had to pull all the gears out with it. I thought it would just come right out. anything i've read or videos i've seen show it come out the case with ease but, not mine. It is stuck half way and would not go back in or out. I tried tapping on it with a brass hammer but that just made it worse now there is no play in it. Guessing something is stuck or? please help as i dont have a clue what to do and am afraid to hit it to hard and break somethinmg. If anyone knows where to go from here please help. Just a fyi. i already pulled all the grears and changed them put bearings back on etc now i just need to put it back together but cant.
