My 1.3 88 sami has a stock carb and won't run. I put fuel in carb and it will idle until fuel is gone. Checked fuel pump and it is good. Can this be an obstruction in the carb or float problem??:(
Not even four hours between posts, did you think there was someone just hanging around waiting to reply to you?
You know there is a carb problem - you don't know what it is, and please tell me you don't really expect us to diagnose it from a distance - yes, the float could be stuck, or the float valve blocked, or a fuel passage, or the primary main jet(s).
This is where you get to decide - am I familiar enough with carbs that I can tear this one down, or do I need to get help or a replacement. The carb on my 1.3 was a double barreled Aisin, simple enough, you look you're in the US, so you would had the electronic feedback Hitachi, which I understand can be a real pain.
Good luck.
Sorry about time on posts just seemed longer. I will pull the top off today with the hope it is the float. Wish me luck.:(
