When i get it up too 40-50 mph it shakes violently on and off. What could be the problwm?
It happened to me when I was slowing down. Do you have bigger tires fitted? This was the problem on my Zuk. The solution seems to be to install a stronger steering damper shock. This helped on mine.
everything is stock as far as i know, im probly going to take it to a front end shop and i planed on replacing the shocks :confused:
hi,if the shaking is just through the steering wheel the front tyres might be out of balance,if the shake is through the whole car it might be the rear tyres as well ,or a uni-joint, prop-shaft problem. hope this helps!
