Sami was running fine but then on theway back from a wheeling trip she started to not wanna idle, she would run alright under some throttle but when I take myfoot off she studders for a couple seconds then just dies, any help.?
sounds like its not getting enough fuel or spark or something like that. I would check fuel lines but mine did something similar before i did the fuel regulator.
I just put mine back oon the road with a 1.6 and after it got warmed up the idle went so low it would stall out. The problem ended up being a bad contact between the temerature sending unit and the sensor that plugs into it. A little wiggle and a push and it was back to normal. Not sure if the 1.3 would have the same effect but it has to do with the computer regulating the idle as the motor gets hot.
