1 - 1 of 1 Posts
Though I had a bad bearing in the pinion, pull everything apart. all look good. Ouestion: Can I reassemble everything back together using the old crush sleeve or do i need to get a new crush sleeve (has new pinion seal put in a couple days before tore it down). I also know I need to set the backlash on the ring and pinion gears
1 - 1 of 1 Posts
