I have a couple of questions: I believe my front crank seal is leaking..Anybody change one and how hard is it to do.. Looks like the radiator and shroud all have to come out..Where did you get the parts, do they come in a kit. Oil leaking pretty good.. Probably should change the timing belt also??
Where is the gear oil fill on the transmission. 5 speed manual? How is the best way to check it...
Any help or suggestions would be appreciated...
I hadto change out the front crank seal on my 87 sammy (1.3L) due to a major oil leak. It was pretty simple. i took off the fan shroud, fan, belt, and timimg belt cover, then remove the bottm pully off. I had my mechanic watching me as I did this and it onlt took a couple of hours.
Unfourtenly my leak came back but not quite as bad. i thin i need to get a crank sleeve.
Oops, I forgot to tell you that I got the part at Oreilly auto parts. i suggets that you get a Chilton repair manuel if you don't have one already. It comes in handy with my sammy. It is a constant work in progress.
