just got the sami to start wit the help of starting fluid. but everytime i get it to start it will run at idle for a second the go higher higher and higher then shut off with me never touching the pedal HElp plz
Discussion Starter #2
changed the plugs and cleaned the fuel filter tank has gas in it and gas is getting to the fuel pilter. what could it be it will run but only off strating fluid. im assuming its not getting fuel but my ? is what should i look for to see where its not getting fuel? it gets fuel all the way to the filter thats the futherest ive checked what else should i look for?
maybe your vacuum hoses are routed incorectly. If the idle climbs from start untill it dies, it could be the cold idle setting, or a defective high idle control.
