Hi, when I engage the 4wd there is a air noise in the differential . Also oil is in the air tube. Bad o-ring seal in the diff? Any way to lock the diff without tearing is apart? Any front diff explode view diagrams out there. Nothing on google that is detailed enough!
Race
The front diff is activated by an air pressure bellow, which is known to rupture..
The pump is located behind the front bumper and should shut down @ +/- 7psi..
If the clutch bellow is damaged, there is no fix other than opening the diff..
Some have repaired (cheapest fix) using Zip ties and installing manual hubs.
..... Philip
