Just purchased a 90 Sammy and it has the green 4WD light stayed on all times in dash. Also the red check engine light. Can help me how to start dealing with. Thanks!
The 4wd light may be a shorted wire. It is one of the two that comes out of the transfer case and goes into the wiring harness on the firewall. It should only be on when the transfer case is in 4wd.
The engine light can be a few different things. First step is to reset the light using the two way switch under the dash. Just flip it to the other side to reset the light.
