hi evryone i would like to know exacle what i would need if i would make my own body lift becose right now i have 8 2inch by 3 inch wide and 3/8 of a inch tick tube that i was going to use thanks
The key bits you need are the female threaded bolts (sleeve bolts?) to go onto the captive bolts. Do you have access to a lathe and have any engineering skills?
I don't have those skills, so I got mine in a kit (both the 2" and then the subsequent 3").
The best one I have seen is the bits4vits kit that replaces the existing rubber block with spacers the same diameter.
Body Lift 2" Poly (Vit/GV) - VITARA / X90 - Bits4Vits WebShop
