I see people are running 245/75r16's (30.5") on stock rims(+45mm offset rims). I want to know if 235/85r16(31.7") would fit with +20mm offset rims? From my calculations they shouldnt rub on the firewall/chassis at full lock due to the offset keeping them away but i have no idea if they would fit in the wheel well when the wheels are straight or if they would rub when at full travel. I dont want to smash my inner wheelwell/doors seals off馃槀
It would be tight. If I remember right most people run the 235/75r16 and some people running it and the offset is mainly to clear the strut.
Are you going to add any lift kit?
Below is stock VS the 235/75R17
I run 245/65R17 with 30MM lift, could run more for sure.
96046
235/85/16 will rub, I tried them on my 2013 3 door 3rd gen. running 235/75/16 on it with no rubbing.
