Good morning,
Is anyone using this tire size?, what are your thoughts? I believe they do fit the 2010 gv and i do like very much the design of the 18 inch oem rims.
Could you share the type/brand of tires you are using?
I need to change tires at the end of this year.
Thank you :)
Marcos
...it should fit the OEM 18" rim. The tire width however, is almost 1.5 inches wider (this could be a major problem if you have the optional plastic Suzuki wheel-well guards). I have not heard of anyone changing tire sizes on OEM 18" rims in this forum; most just go with 17" or 16" rims, and "big meats".
Have a look at all the technical parameters switching from OEM tire on Suzuki OEM 18" rim:
225/60-R18 vs 235/65-R18 Tire Comparison - Tire Size Calculator
*tire and performance calculator from the Taco (Toyota Tacoma) Forum website
If you look at the tire size calculator, the new size is almost 5% bigger than the original size. It will put a strain on your brakes.
