2020 Jimny horn is one pin and 2018 swift is too
But connector look like different
So Jimny horn can change to Swift?
What are you trying to do? Use the two wire Swift horn in the Jimny? Connect the Jimny wire to one of the terminals on the Swift horn and wire the other terminal to ground.
The one wire horn can also be used in place of the two wire horn, if you know what you're doing. This MAY require a relay and some additional wiring, so unless you have a specific reason for doing it, it'll probably be more cost effective to simply get the correct horn - I really don't see anyone wanting to use a Jminy horn in any other vehicle - it's the most anemic sounding horn I've ever heard on a new vehicle.
Reactions: OnePeddleMissin
Go buy a decent aftermarket horn, they are louder than the sheeps fart factory ones for sure.
One and 2 pins are available from any reputable parts store.
Or, want to really scare anyone that cuts you off, get a 120 db motorcycle horn.
Buy a horn with the same number of wires as the one in the car, fitting it will be easier.
