its in the owners manual.
Suzuki Swift Automatic Transaxle Dashboard Warning Light Symbol
Transaxle (Amber)
The cog or gear symbol is the Suzuki Swift transaxle warning light. This light comes on briefly with the ignition or engine button set to ON. If the light comes on when the engine is running, there is a problem with the automatic transaxle system.
Urgency: Medium
This usually relates to an issue with the automatic gearbox / transmission. Drive at a moderate speed and avoid pushing the gearbox through excessive strain. Have system check as soon as possible. For CVT models, if the CVT fluid temperature becomes too high, this light will flash. Stop the vehicle and allow to fluid to cool down.
In second look, I’m not sure it is the transaxle warning light. The light I’m getting looks more like a lightbulb.
ok,apologies, Looked like the CVT / transaxle warning symbol in the first pic
this too is in the manual
Either way, off to the dealer you go with a warranty issue.
Suzuki Swift LED Headlight  Dashboard Warning Light Symbol
LED Headlights
This symbol represents the Suzuki Swift LED headlight system. The light comes on briefly when the ignition or engine start button are set to ON.If this warning light comes on and stays on, it indicates a fault with the LED headlight system.
