Absolutely Pee'ing it down outside but the postie did bring some minor upgrades...
First up, a bootmat... all the times that I'll have filthy mountain bike clothing & helmets or soaking snowboard or fishing gear, least i know the carpet wont be getting stained or soaked..
also had the mudflaps delivered, fronts are a 5min job...
you prise open the 3(of) retaining clips from each flap like this....
Then simply push in and screw up the new 'longer' clips that come with the new flaps..
I forgot to take a picture when these were off the car and when it stops raining, I'll get a better snap.. fitted a treat and a perfect fit.
the rears take a bit more work as it’s a wheels off job.
you need to hold the mud flap against the arch and mark where your pilot holes go. (A sharpie does the trick).
I used a 2mm drill bit.
once drilled you simply screw in the self tappers.
at £28 for the fronts and rears. They’ve worked out pretty well
