1 - 20 of 54 Posts
· Registered
Afternoon all, quick introduction to myself and my new (to me) 2016 Vitara S
Having owned many different cars and been a member of many MANY forums, best way to kick off is with an ownership thread!!
Evo 8’s 2003 Evo VIII mint... £14,500
Wheel Car Tire Vehicle Land vehicle
Megane 225’s Martin1977 's 'CUP' Adventure
Wheel Tire Car Vehicle Plant
I’d actually previously owned a 2007 Grand Vitara a few years back. An ace little thing that only let go after a spark plug ‘tip’ came off and went through the cylinder! Thanks BOSCH super 4….
One ruined engine later and my £300 purchase / 24K love affair was brought to an abrupt halt… black arm band day indeed….The car had performed BRILLIANTLY.. Going through deep mud / deeper snow / kid school runs without issue. It was indeed a FINE car.
Previous to this Vitara though, I’d owned a Kuga 2.5T in manual, not many of them going around.. The 275BHP was GREAT.. overtaking no problem, Macan baiting.. a pleasure….the rate of unleaded consumption… much less of a pleasure returning on average 26mpg.. that and the £600+ car tax pain made it a fun but wallet emptying 4years…
Kuga 2.5T 2.5T KUGA Adventure
Wheel Tire Vehicle Car Hood
ANYWAYS……. Today brings a new chapter and this little beauty in a charming ‘Essex White’ colour….. nice to drive, frugal… more modern.. it’s a good compromise..
As with all things, it needs some careful adjustment…..
After Exactly 96x minutes of ownership, First up is a software update to enable CAR PLAY.. I’ll also get an updated NAV micro SD from Le Bay…. CarPlay is all fine and well.. sometimes Im out in the wilds (fishing and snowboarding) with no phone signal so it’ll be worth the £20 for when its needed
Motor vehicle Automotive design Personal luxury car Electronic device Display device
Motor vehicle Vehicle Automotive tire Automotive design Car
the info given on the forum by @Ticking_Fox was brilliant to fix.
Next Up, the car is fitted with 4x new tyres… Now. there are tyres and TYRES.. (these are the former).. they’re made of rubber and are worth every one of His Majesty’s £20 Pounds they probably cost to buy… guaranteed to find a ditch every time….
So, they’re going. They’ll be replaced by these Nokian Winter beauties… I’ll get them fitted tomorrow. New (summer) wheels will be fitted in the spring.
Tire Wheel Automotive tire Black Tread
Tire Wheel Automotive tire Tread Synthetic rubber
After that, the following is planned:
  • Dashcam hard wired
  • LED Number plate lights / Side lights / Interior bulbs
  • Mudflaps installed
  • Roof rack fitted
  • Spare wheel purchased
  • Swanky key ring purchased
All in the days to come! Thanks for having me along.
· Registered
Discussion Starter · #2 ·
With an hour to kill before the Mrs and I headed out, this morning was DashCam fitting time.
Anyone whos ever gone through the PITA that is contentious insurance claim, these things are worth their weight in gold… maybe even diamonds.. simple to fit, saves a lot of BS.
fitting is straightforward..
I mounted mines up behind the rear view mirror, means it gets a good view of the road and is hidden from the drivers view.
the power cable tucks up nicely under the headlining, I used a trim tool to push her underneath.
pull The door seal outwards and you can see a route to put the cable down the edge you’ve just exposed.
the fuse box is in the passenger footwell (LHS). The two pieces of trim gently pull away. This exposes the fuse box.
for anyone who doesn’t have an owners manual, here you go.
Product Font Material property Parallel Pattern
Font Material property Parallel Paper Monochrome
you have a choice of where to plug the dashcam into.
I went for fuse 29. This switches on and off with ignition which is exactly what I wanted.
you need a piggyback fuse holder like this.
Automotive lighting Finger Thumb Nail Body jewelry
simply remove the factory fuse, they’re a pain to get out.. and plug your piggyback holder in its place.
Automotive tire Gas Electrical wiring Machine Space
J
There’s a handy earthing bolt right where you need it!!
your dash cam also doesn’t work on 12V.. it’s 5V, a bit like USBs.. you need a little power transformer to wire in line..
both can be seen here..
Leg Automotive tire Hood Motor vehicle Automotive design
once installed power her up and make sure it switches on and off with the ignition…
Automotive side-view mirror Automotive lighting Motor vehicle Automotive mirror Mirror
Mirror Car Vehicle White Automotive lighting
best to do this on a warm day.. the fuse box is fiddly and awkward to get into.. cold hands make this tougher than it should be!!
· Registered
Suzuki Vitara SZT, White, 1.4 T Gdi, 6 speed manual.
View attachment 108245 J
[/QUOTE
Good dashcam fitting guide. I fitted my dashcam in the same way.
· Registered
Discussion Starter · #4 · (Edited)
Absolutely Pee'ing it down outside but the postie did bring some minor upgrades...
First up, a bootmat... all the times that I'll have filthy mountain bike clothing & helmets or soaking snowboard or fishing gear, least i know the carpet wont be getting stained or soaked..
Car Vehicle Motor vehicle Trunk Automotive design
also had the mudflaps delivered, fronts are a 5min job...
you prise open the 3(of) retaining clips from each flap like this....
Tire Wheel Automotive tire Tread Motor vehicle
Then simply push in and screw up the new 'longer' clips that come with the new flaps..
I forgot to take a picture when these were off the car and when it stops raining, I'll get a better snap.. fitted a treat and a perfect fit.
Tire Wheel Automotive tire Synthetic rubber Tread
the rears take a bit more work as it’s a wheels off job.
you need to hold the mud flap against the arch and mark where your pilot holes go. (A sharpie does the trick).
I used a 2mm drill bit.
once drilled you simply screw in the self tappers.
Tire Automotive tire Automotive lighting Gesture Finger
Automotive tire Chair Synthetic rubber Plant Motor vehicle
at £28 for the fronts and rears. They’ve worked out pretty well
· Registered
Discussion Starter · #5 ·
I also managed to change out the following filament bulbs to LEDs.
  • reverse lights
  • fog lights
  • Main Beams
Automotive tail & brake light Vehicle Car Automotive parking light Grille
Tire Automotive tail & brake light Vehicle registration plate Wheel Plant
Automotive side marker light Automotive tail & brake light Tire Car Vehicle registration plate
Automotive tail & brake light Vehicle Car Automotive lighting Hood
rears we’re up first… pretty easy when you pull off the trim panel from the inside.
beneath the lights is filthy, so give it a clean while you’re there… the pics above show one light fitted at a time.
full beams were the easiest change, the fog lights need a good long reach.
Automotive parking light Vehicle registration plate Vehicle Grille Hood
Nearside fog bulb changed…
Vehicle registration plate Grille Tire Hood Vehicle
both fog bulbs changed
Automotive parking light Vehicle registration plate Car Vehicle Grille
dipped, fog and main beam on LED.
Road surface Yellow Asphalt Font Tar
standard LED dipped lights below..
Building Automotive tire Grille Hood Automotive lighting
add in the fogs….
Automotive tire Automotive lighting Window Hood Motor vehicle
· Registered
Discussion Starter · #7 ·
That’s the winter rubber fitted in 225x55x17 flavouring… the white stuff shouldn’t be an issue when it arrives
Tire Wheel Vehicle Car Automotive tire
also the roof rack and bike holders now in place.. they work well but generate an annoying ‘whistle’ above 60mph 🙄
Automotive parking light Tire Car Wheel Vehicle
· Administrator
I don't think you'll need spigot rings, but if you do, you'll also need new lug bolts - check the seat on the rims, is it tapered or flat? If it's tapered the rim is lug centric and does not need spigot rings, if it's flat, the rim is hub centric and you'll need the rings and the shanked lug bolts to match.
Beats me as to why Suzuki switched from lug nuts on the previous generations of Vitaras & Grand Vitaras to lug bolts on this one.
· Registered
Discussion Starter · #10 ·
Good catch that thanks. I’ll get one of the wheels out of the box tomorrow and have a quick look.
just so I’m not misunderstanding… the spigot ring is for reducing the wheels CB (centre bore) down … where as the bolt seat, is the fitting between the bolt and the wheel face (flat or tapered)… ???
· Registered
Discussion Starter · #11 · (Edited)
I’d picked up on a very minor fault , which has led to my first repair today… a broken track on the rear screen demister!!
Wheel Bicycle tire Window Automotive tire Tire
zoom in real close and you can see the damaged area… could have been caused by something rubbing against it?? Who knows…
Rectangle Shade Wood Tints and shades Tree
a £5 on eBay had conductive paint delivered… I haven’t used it for years and years but it’s an old school technology!!
Brown Hand Liquid Bottle Product
mask up the area as carefully as you can, be very careful you don’t peel more track away as masking tape is bloody sticky and put a small amount on
Grey Rectangle Automotive design Automotive tire Material property
Hood Automotive tire Automotive design Grey Automotive exterior
Once the tape is removed, let her dry….
Building Window Sky Cloud Grey
I forgot to take my phone out when I tested this with a pan of hot water.. she's working again though!
· Registered
Evening Martin
following your thread with interest
I purchased a 2015 sz5 a week or so ago and am sort of on the same path as you with little mods and upgrades
currently thinking about a set of Eibach 30mm lift springs but a little unsure of the long term effects on things like driveshafts etc
anyway, can I ask a really cheeky favour …… been trying to update infotainment firmware but as yet with no success for one reason or another …. Anyway, back to the favour, if I pay for the memory stick and the postage could you send me a copy of your updated files so I can try to update ?…
was going to pm you but can’t seem to find a way to do that !,
cheers
chris in Wigan
· Registered
Discussion Starter · #13 ·
Evening Martin
cheers
chris in Wigan
Hey Chris, thanks for the post above.... The +30mm Eibach springs sound like a really good idea... The issue on premature driveshaft / CV wear you'd need someone with experience running the kit long term to give some better advice than I could. My thoughts on it would be purely anecdotal!!
sure thing about the update file. I'll DM you now.
· Administrator
Personally I would be hesitant to lift a fourth generation Vitara - the front suspension is very similar to that of the third gens in that the lower control arm uses a vertically oriented rubber bushing. This design is very common in front wheel drive sedans & cross overs (I first came across it in a late 90's Toyota Corolla and have seen it on many other models) and attempting to lift the vehicle or to maximize suspension travel usually results in premature failure of the bush.
I haven't had my fourth gen long enough (and have no intention of lifting it) to know what the life expectancy of the bush is, but I've already replaced the control arms on my third gen a few times, and that isn't lifted either.
· Registered
I have spoken to a chap who has fitted the eibach springs and he informed me that he has had them fitted fo r approx 2 years with no issues as yet. He said he spoke to eibach prior to purchase and although the did suggest he should change the shocks, the said there would be no issue using the standard shock as with only a 30mm lift they would still be in their operating range ?
I was initially concerned as many years ago I fitted a suspension lift to a series one freelander and although I had no issues it did alter the angle of the drive shaft quite a bit and from memory I think I had to fit camber adjustment pins
I think someone on here has them fitted …. I will try to find the post and ask if there have been any issues
Chris
· Registered
Dealer here lifted their demo one 30 mm, lower control arm bushes are shot after 30,000 kns. They haven't mentioned anything about cv shafts yet, but I bet they will wear faster as welll
Reactions: martin1977
· Registered
Sounds like the springs may not be a good idea ……
Has anyone any experience for fitting strut spacers as a way of getting a body lift ?
Again I fitted some of these to an early freelander and only issue was I had to fit longer front brake lines. Doesn’t get you any suspension advantage but does give some body ground clearance
Chris
· Registered
Chris
There's are a monocoque design, not a body on chassis vehicle.
The strut spacers only pack the strut away from the body at the top of the suspension tower, the bottom is still connected to the lower control arm outboard end via the wherl hub, the inboard end bush is still bolted to the body and will be moved to its new location once the strut spacers are fitted.
Same deal as fitting a longer spring/strut combination, bottom bush location does not change.
· Registered
I've been running the Eibach +30mm springs on my Vitara S for 3 years / 18000 miles, no deterioration of the control arm bushes as yet. Rear drive shafts now run closer to horizontal than they do as standard and the front shafts are only slightly off horizontal. Nothing has failed or fallen off yet.
Running factory dampers too.
· Registered
I was hesitant,
but then I mounted the "Mad HV-391081" springs
+ 40mm after 2 months settling
10,000 km and no problem for now, (fingers crossed)
pro:
height from the ground, comfort on dirt roads
cons:
sportsmanship is lost on paved road,
directionality is lost with tires that are too soft (pictured)
Wheel Tire Vehicle Car Plant
1 - 20 of 54 Posts
